Deletes a peer switch from the This command is available on all Universal switches supported in this document. structure.
peer_name |
Specifies an alpha numeric string identifying the MLAG peer. |
N/A.
This command deletes an MLAG peer switch from the association structure.
Before you delete an MLAG peer switch, you must disable it. If it is not disabled, the following error message is displayed:
ERROR: MLAG ports currently associated with peer. First disable MLAG ports using "disable mlag port <port>" before deleting MLAG peerThe following command deletes a peer switch structure switch101:
# delete mlag peer switch101
This command was first available in ExtremeXOS 12.5.
